Apolo1
Active member
Cars owned: Few Porsches, and others
				Fair play & well done beating an R500 around a little circuit like that!
Thanks Paul,
The 918 is big lump to pull round there, the torque out of the low speed twisty bits was insane. Some of the entry points are blind, you approach at over 100mph, at one point is about 1.1/2 cars lengths wide, get the braking wrong and you are off....
While you are on, not sure if you are aware one point I forgot to mention on the way your 991 GT3 box works, next time you go out on track keep it manual mode, do about 3 laps and find your optimum gear change points. Then put it in Auto, the box will recall your change points round the track, leaving you to focus on apex and braking.....
The GT3, RS, and 918 does this not the TTS though but it is on the Facelift
