I had the TPM alert on my M135i last week, pulled over and sure enough the tyre it identified was low on air, so I checked for obvious damage, nail etc but found nothing, after pumping up to about 40psi I stood and looked at it for a but but it seemed to be staying up so I tundled off to the nearest tyre depot...
...it's not a puncture they said but a crack....offside rear wheel with a visible crack across the edge of the rim...
So it went back to BMW, apparently they do an "ovality" check and if the wheel is running out more than 3mm it's your fault for hitting a pothole/curb to hard, if it's less than 3mm then they will consider replacing it. Mine was 0.03mm out and so they replaced it, I was relieved as they charge just short of £500 for a replacement.
I've heard of cars having issues with 19" wheels with runflats but not 18" with non-runflats.
